Luth Posted June 8, 2012 Posted June 8, 2012 For the computer i record tv-shows i get the file info just fine, like this: and file details: But when i copy the file to another computer which i use to edit the files i dont have any info about the file: and: Both computers have latest DVBViewer pro installed. How can i get the recording info to work with both computers? Thanks. Quote
majstang Posted June 8, 2012 Posted June 8, 2012 Try with installing DVBViewer Recording Properties on the other computer as well. Quote
Luth Posted June 8, 2012 Author Posted June 8, 2012 Update: The computer where the info is shown has windows 7 ultimate 32bit. The other comp where info is not shown has windows 7 ultimate 64bit. Is this the problem? From members/beta section i downloaded and installed DVBViewer Recording Properties to the x64 computer but still no info available. Its still excatly as it was on the screenshot i posted :/ Is there anything i can do to get it to work? Quote
Derrick Posted June 8, 2012 Posted June 8, 2012 The other comp where info is not shown has windows 7 ultimate 64bit.Is this the problem? yes, win7 doesn't show this information. Quote
majstang Posted June 8, 2012 Posted June 8, 2012 (edited) @Luth DVBViewer Recording Properties v.2 supports 64-bit. If you use the search function you will find the information Read this link: http://www.DVBViewer.tv/forum/topic/48856-DVBViewer-recording-properties/ Edited June 8, 2012 by majstang Quote
Luth Posted June 8, 2012 Author Posted June 8, 2012 Oh well. I reinstalled DVBViewer and reinstalled the beta DVBViewer Recording Properties. Still no recording info is shown for the files (win7 64bit). On 32bit system the infos are shown correctly. Too bad if it doesnt work with 64bit win7. Support.zip included for the non working x64 system. support.zip Quote
ml 05019 Posted June 8, 2012 Posted June 8, 2012 How do you transfer the files to another computer? USB flash drive or...? Because when I copy files on USB flash (FAT formatted), my computer warns me that metadata cannot be copied to a FAT formatted disk and it will be deleted. Try using TeamViewer or local network to copy the files. Quote
Luth Posted June 9, 2012 Author Posted June 9, 2012 I have both computers on my home network. So i just copy paste. Also i tried with VNC. Somehow the info goes missing somewhere. Need to try with NTFS formatted HDD, then ive tried everything i could think of. Quote
majstang Posted June 9, 2012 Posted June 9, 2012 Need to try with NTFS formatted HDD, then ive tried everything i could think of. The fileinfo will disappear if using any format other than NTFS. Only NTFS does support the fileinfo. That was what ml05019 meant with his post. Quote
Luth Posted June 13, 2012 Author Posted June 13, 2012 Ok so i tried moving the .ts from working 32bit system to 64bit system with FTP, VNC, home network copy paste and NTFS formatted HDD. No file info on any of the files. So i guess the recording properties does not work for x64 :/ Quote
ElecardFAN Posted June 13, 2012 Posted June 13, 2012 Na, they do work - since you see the recording panel in the property window. The reason why it is empty is caused by the loss of these informations. They are stored on NTFS drives, but if you copy the file to a fat file system device you loose the additional informations. I'm not sure but the property plugin does support additional txt files i guess, so you might also copy the txt file for the ts stream. Peter Quote
