peon Posted June 10, 2012 Posted June 10, 2012 Hi, Sometimes when i start DVBViewer i get a black screen no video or sound, if i restart DVBViewer a second time it always works. The same if i switch to video output b and back.. Ive actually got this problem the past 12months have tried diffrent kind of codec but sometimes it behaves the same, anyone got a idea what it can be? Im running cyberlink codec with customrender (evr cust) gfx: ati hd 5570 driver: newest catalyst please help Quote
highyield Posted June 12, 2012 Posted June 12, 2012 You should have specified what DVB tuner you are using. It's probably a bug in your tuner's driver, it's not DVBViewer's fault. I have the same issue (Terratec Cinergy T PCIe Dual, Windows7 64 bit). Quote
bogdan1980 Posted July 20, 2012 Posted July 20, 2012 I was having this also, but its fixed now. Maybe latest DVBViewer version fixed this. Quote
majstang Posted July 21, 2012 Posted July 21, 2012 Yes, I had it too and it was fixed in DVBViewer 4.9.6.20 Quote
bogdan1980 Posted July 27, 2012 Posted July 27, 2012 This was an awsome bug fixed, with latest version my previous channel always work at startup. Quote
peon Posted October 6, 2012 Author Posted October 6, 2012 hey, im using two technotrend c-1501 ... still getting this issue but im using dvbrecording service so DVBViewer should only use my uni cast devices. ill try uncheck prev chan if it helps. Quote
