problems with DVBViewer Pro 4.9.6.20
Residentcl
Hi all.
I tell him my problem.
I once had the same problems with a pirated version,
but now I have my legal credentials from yesterday happily.
so come to see if a solution is possible.
1: Sometimes I look at the browser, folder or program and look DVBViewer Pro and see the attached program,
how strange it is stuck 10 seconds and is normally 5 seconds and then sticks again and so to close the program or remove the tuner usb pc.
signal is typically a %69 but when left in sticks %99
2: Sometimes I start DVBViewer Pro and remains so.
I have to remove the pc usb tuner so you can watch tv.
3: when I watch something else on the same pc or options of DVBViewer Pro is like in slow motion,
and sometimes the video is out of sync with the audio, you need to tune the channel again.
detail of pc:
TV Tuner: Brand: Aktiz. Model: ATO-051. TV standard: ISDB-T.
driver: 1.0.0.1 here the driver if necessary link
device name: SDMC BDA Tuner Filter.
Operating System: Windows 7 64 bit sp1.
RAM: 4 GB DDR 2.
Processor: Intel ® Pentium ® Dual CPU E2200@2.20GHz.
motherboard: Brand: ECS. model: GF7100PVT-M3 (V1.0).
Graphics Card: Brand: ati. Model: ATI Radeon HD 4600 Series.
Driver: 12.4
separate question: Is the TV tuner is compatible with the remote with DVBViewer Pro?
thank you very much in advance for your answers.
sorry for the English.
greetings from Chile.
1 & 2: If you need to restart DVBViewer or you have to physically remove the tuner to regain normal operation, that's probably caused by the tuner's driver. Also, signal variations have nothing to do with DVBViewer.
3: You need to monitor your CPU usage. It's probably too slow and falls behind work. You may improve the behaviour by choosing some other video codec, depending on the stream type. Something like LAV filters (which I don't use, but you can try it)
Edited by highyield
ok, I'll look at a driver that I have another brand from another is the same model.
on the processor, with all I have available codecs always use %20.
here pictures with the codec available and processor usage. link
Filters LAV was a time, is of very poor quality in my case the coder.
device name: SDMC BDA Tuner Filter DM1305GHIJKLMNOP.
Edited by Residentcl
and, now I have the problem of TV Tuner.
highyield thanks.
I just have the problem number 3:
When I watch something else on the Same PC or options of DVBViewer Pro is like in slow motion,
Sometimes the video and is out of sync with the audio, you need to tune the channel again.
sometimes when I change channels, I get the audio, I have to retune the channel and there I get good audio.
Separate question: Is the TV tuner is compliant with remote With The DVBViewer Pro?
  • 4 weeks later...
Problem 1 and 2: the problem is the power of the PC. now I have fewer things and doing really well.
Problem 3: now I have it on Windows 8 with no problems.
