Service hangs.
What this error mean?
http://japesone.kapsi.fi/loadfile.php?prefix=svcdebug.log
18.06.12 05:50:35.638 TUniCastServer Could not listen: Address already in use (#10048 in Bind)
18.06.12 05:50:35.638 TDVBWebserver.Connect Could not connect 127.0.0.1:8089
18.06.12 05:50:35.639 TDVBWebserver.Connect Could not connect 192.168.0.11:8089
18.06.12 05:50:35.639 TStreamManager.Connect Could not connect 127.0.0.1:7522
18.06.12 05:50:35.639 TStreamManager.Connect Could not connect 192.168.0.11:7522
18.06.12 05:50:45.778 TUniCastServer Could not listen: Address already in use (#10048 in Bind)
18.06.12 05:50:45.779 TDVBWebserver.Connect Could not connect 127.0.0.1:8089
18.06.12 05:50:45.779 TDVBWebserver.Connect Could not connect 192.168.0.11:8089
18.06.12 05:50:45.779 TStreamManager.Connect Could not connect 127.0.0.1:7522
18.06.12 05:50:45.780 TStreamManager.Connect Could not connect 192.168.0.11:7522
Edit:
I can't connect service web interface and client cant connect to service.
What happens? I try older version too, no change.
My home network works ok.
Please help, if you have any idea what i can try.
Now i don't have tv at all.
Edited by janip
well something blocks the RS from accessing the networking components. Maybe the Anti virus program?
I use avast, i try to stop it too. No change.
How i can check, if some other program use those same ports?
But only those 8089 and 3456 ports wont work, my freessHD server 22 works ok.
I think that other service instans are stolen those port...
Can't understand why.
Edit:
Yes that is what happens.
I change port to 8081 and 3457, now web interface works ok, but dvbv can't connect to service.
Ok,
now all works again, i forget change unicast device port from DVBViewer.
Do you have any idea what happens?
Recservice hangs this night, i only see that red recordins icon.
Have to kill service. And then that port issue starts.
Edited by janip
