How do I set unique eventID
malcolm user
I'm using C#
NewEPGItem is type IEPGItem
NewEPGItem = AddEPG.NewItem();
NewEPGItem.Content = 0;
NewEPGItem.Charset = 255;
NewEPGItem.Description = icerik;
NewEPGItem.Title = icerik;
NewEPGItem.Time = DateTime.Parse(zaman + " " + koleksiyons.Groups[5].Value);
NewEPGItem.EventID = <<<<// How unique setting eventID ?? There are only the latest epg, epg window problem
Edited by malcolm user
I can download a TV web page in tv guide to listview..
but
But all Epg Item does not seem epg window only one EPG ıtem seem
IEPGItem NewEPGItem, EPGItem;
       IEPGCollection EPGCollection;
       IEPGAddBuffer AddEPG;
       ListView ekle;
       void yeni_DocumentCompleted(object sender, WebBrowserDocumentCompletedEventArgs e)
           ekle = new ListView();
           saat = DateTime.Now;
           DateTime zamaninki = DateTime.Now;
           taske = yeni.Document.GetElementsByTagName("div")[42].InnerText;
           AddEPG = DVB.EPGManager.AddEPG();
           IEPGCollection atbuna = DVB.EPGManager.Get(1, 16, DateTime.Now, DateTime.Now.AddDays(7));
           int yeniSayi = 65000;[b]//I wrote this number by chance[/b]
           koleksiyons = Regex.Matches(taske, maske);
           for (int i = 0; i < koleksiyons.Count; i++)
               if (koleksiyons[i].Groups[1].Value != "")
                   zaman = koleksiyons[i].Groups[1].Value;
               else
                   if (DateTime.Parse(zaman + " " + koleksiyons[i].Groups[5].Value) > DateTime.Now)
                       int k = 1;
                       icerik = koleksiyons[i].Groups[9].Value;
                       NewEPGItem.Time = DateTime.Parse(zaman + " " + koleksiyons[i].Groups[5].Value);
                       NewEPGItem.EventID = yeniSayi; // [b]I think the problem here stems I can not set unique eventID[/b]
                       NewEPGItem.SetEPGEventID(DVB.CurrentChannel.Tuner.SID, DVB.CurrentChannel.Tuner.TransportStreamID);
                       NewEPGItem.Duration = DateTime.Parse("00:00:00").Add(NewEPGItem.Time - zamaninki);
                       int zarto = ekle.Items.Add(zaman + " " + koleksiyons[i].Groups[5].Value).Index;
                       ekle.Items[zarto].SubItems.Add(icerik);
                       zamaninki = DateTime.Parse(zaman + " " + koleksiyons[i].Groups[5].Value);
                       AddEPG.Add(NewEPGItem);
                       AddEPG.Commit();
                       yeniSayi++;//Plus plus
                       this.Text = yeniSayi.ToString();
           AddEPG.Commit();
           bunat(ekle, "DENEME");
Sorry for bad English is :blush:
The eventID is a Dword (32bit). And it has to be unique for a given epgchannelID (http://en.DVBViewer....Service_API#EPG). So the best way would be a (unix)datetime created of the startdate and time for each entry. You could also use any other 32bit value which represents this, as long as you can reproduce this value for existing entries.
@Lars_MQ
Very thank...
Now works all seem :D
