RS 1.10 Timeline tooltip missing
Can't get the tooltips working on Timeline, despite having it enabled. They do show up as the should on every other menu tab though.
EDIT: Works with IE9 but not with Chrome
Edited by majstang
I can confirm this. Directly after update to 1.10 they were there but after a page reload they are gone. So they worked initially only because of the cached old script. Does not work here with IE9 or Firefox.
@majstang: Press F5 or Ctrl-F5 in IE9 and see if it's still working for you
Please extract the timeline.min.js into the SVCWeb\js\ folder and reload the page in the browser.
timeline.min.zip
Thanks, that fixes it :)
here too :biggrin:
Great, thank you.
