Simon82 Posted October 10, 2004 Posted October 10, 2004 I was thinking that could be an idea to implement something to disable the s2 card when DVBViewer is off. I've seen that in BC2C proprieties there's a option called "Stato alimentazione corrente" (current alimentation status ) that change when you disable the card from device manager from D3 or D1 to D0 when it's running. The difference in heat is big. When it's disable the card is cool.. when is enable the card is hot. When DVBViewer is off coudl be an idea to change this parameter to cool the card. What do you think? Quote
Klausing Posted October 11, 2004 Posted October 11, 2004 try boardseach .... there you can find the solution .... Quote
Technofriend Posted October 11, 2004 Posted October 11, 2004 Tolle Idee. Schon verwunderlich, dass da vor Dir noch keiner drauf gekommen ist. *frechgrins* Quote
