Disklimit reached!
Mr Jolly
Hello all, I am having a small bit of bother with one of my DVBViewer recording system.
Recordings will stop and I get a Disklimit reached! written to the log file.
15:55:00 / 00:00:00 (~ 0.0 MB) Start
15:55:01 / 00:00:01 (~ 0.0 MB) PID 1002: MPEG Audio J. Stereo, 48 khz, 192 kbps
16:03:17 Disklimit reached!
16:03:20 / 00:08:19 (~ 11.4 MB) Stop
Average Data Rate: 0.023 MB/s
Total Size: 11.4 MB (11928960 Bytes)
Here is the last instance. Any clues as to what could be causing this or what this error means?
Do you have enough disk space to store recordings including the extra free space specified in the DVBViewer configuration?
I thought I had attached the support.zip, will try again.
Not enough space on your hard drive?
Hiya and thanks for your replies. I have plenty of space, 500GB drive with 170GB used, I also only ever record radio and about 3GB across 7 days with no more than 2 x 192kbps streams being written to disk at the same time.
What circumstances within the program cause that precise error to be generated?
Is the disk active for recording ?
Look at "Status Tab" in Web front end.
There should be your drive/folder with the remaining diskspace.
By looking at your config, I see that you've set C:\recordings as recording folder. Does DVBViewer manage to create any file in that folder? Maybe it doesn't have the appropriate filesystem access rights.
