PerryM Posted July 6, 2012 Posted July 6, 2012 support.zip I recently had to re-format my media HD - actually a pair of disks in RAID 0. I also updated RS and DVBViewer. Since then the recordings are very erratic - typically having many attempts at making a file. I thus end up with as many as 30 files of the same show. I just tried updating RS to 1.10 but still the same. I repeat that it is very random, sometimes it works fine - sometimes not. I am sure it is something silly I do but help would be appreciated.
Gioxy Posted July 6, 2012 Posted July 6, 2012 From your Systeminfo.txt: MS Media Center Receiver Service: Running MS Media Center Scheduler Service: Running ...that can be one (or the) source of your rec problems...
PerryM Posted July 7, 2012 Author Posted July 7, 2012 OK - with a fair amount of work (and a lot of Googling) I've disabled all the Media Center stuff I can find (please see attached support file) but it hasn't made any difference. Any more ideas? support.zip
PerryM Posted July 9, 2012 Author Posted July 9, 2012 Well a combination of an RS re-install and a complete retune seems to have fixed the problem for now! Keep your fingers crossed for me.
