chp Posted July 12, 2012 Posted July 12, 2012 Hi, Anyone knows how to use the "OSD Resolution Converter tool" available to download here: http://de.DVBViewer.tv/wiki/OSD_(Plugins) ? Or, where to find a manual for it? Quote
Tjod Posted July 12, 2012 Posted July 12, 2012 There is no manual, in the original post Christian refers to the source code as documentation. http://www.DVBViewer.tv/forum/topic/38303-x-skin/page__view__findpost__p__291982 http://www.DVBViewer.tv/forum/topic/19905-osd-skin-xic3/page__st__120__p__164510#entry164510 As far as I can see you have to run the Sample.exe in the Skin folder with two or three parameters. 1 > RatioX 2 > RatioY 3 > Minimum (optional) But this will only change most values in the .xml files. So this is only a start point for porting a Skin to a other resolution. Quote
chp Posted July 12, 2012 Author Posted July 12, 2012 Thanks Tjod, Do you mean I just have to put the 2 files included in the ZIP file into the desired skin folder, change the 2 folowing lines in the "sample.dpr" file: From RatioX := 1024 / 1366; RatioY := 768 / 768; to RatioX := 1024 / 1920; RatioY := 768 / 1080; to match my resolution, run the program and voilà? Quote
Tjod Posted July 12, 2012 Posted July 12, 2012 No the sample.dpr is the delphi source code of the program. http://en.wikipedia.org/wiki/Source_code Sample.exe is command line program Quote
chp Posted July 12, 2012 Author Posted July 12, 2012 Uh.... me bad. So, do you have an idea what could be the command line options? I'm not a programmer and I don't understand the source code. Quote
