dvd viewer no tool bar
jpdamigaman
HI I had DVBViewer installed before and it had a tool bar at bottom of screen.
I had to reinstall it and the tool bar is not there like it was before for time shifting and moving video on.
I used it with win 98 se before as I'm doing now I've got windows media player 9 installed.
I payed for the extended version.
yours
I have downloaded a new version i'm using now. the older version was the way it should be!
yours
Paul Davidson
Go to Settings/ Options/ Enhanced. Tick the "Control bar Popup Delay" checkbox. Set the delay to 100 ms or so (won't work with 0 ms or if the checkbox is un-ticked - a small bug).
Don't see that check box?
yours
paul Davidson
