dvbrewer Posted July 28, 2012 Posted July 28, 2012 (edited) With the Olympics the schedule changes a lot, but the EPG will not update even if you go to the channel with the altered schedule. It seems the only way to get round this is to turn off Persistent EPG data, close DVBViewer and repopulate, then go to the channels with empty EPG to fill in the gaps. So the question is, can DVBViewer update the EPG with the changed data without doing having to restart, and repopulate EPG? Edited July 28, 2012 by dvbrewer Quote
dvbrewer Posted July 30, 2012 Author Posted July 30, 2012 Can someone respond to this issue whether it can be fixed or not as it is quite annoying as the schedule changes so much, and both Sky & Freesat boxes update correctly, but not DVBViewer. Quote
