bogdan1980 Posted July 28, 2012 Posted July 28, 2012 I installed DVBViewer in folder 1, then copy all the contain in folder 2, to have 2 DVBViewer instances. I could start and watch 2 different DVBViewer instances, on 2 channels on same transponder. But if i start another instance( DVBViewer 3 or 4) no image is shown. I need at least 4 DVBViewer instances...but only 2 is working. im doing something wrong? Any of you that use 3-4 instances instead of mozaic? i use UserMode=2 for all instances, and also use Root=CMUV\DVBViewer,Root=CMUV\DVBViewer 2, and Root=CMUV\DVBViewer 3. thank you. Quote
Tjod Posted July 28, 2012 Posted July 28, 2012 One TV-card can be only used by one program. So make sure that one card is only active in one instance or in the Recording Service. Quote
fxv1 Posted July 28, 2012 Posted July 28, 2012 AS TJod said ...I have a dual tuner DVB-T2 tuner and a single tuner DVB-S2 tuner so can run 3 DVBViewer instances. great for the olympics .... plus iPlayer if you need more than 3 tv channels !!! Quote
bogdan1980 Posted July 29, 2012 Author Posted July 29, 2012 (edited) I use rec service, card is active in rec service, in the rest i use unicast( for DVBViewer windows). Still, third DVBViewer instances not working. EDIT: fixed it, i delete hardware on DVBViewer 3, add unicast again, now working. Pfiu:D Edited July 29, 2012 by bogdan1980 Quote
