PSIRiders Posted August 2, 2012 Posted August 2, 2012 Hi, I have a problem having multiple CAM modules with cards from different operators (multiple TBS 5980 cards). Since in Poland dish operators use same transponders/channels with different CAID, when I set the channel, that I don't have a valid subscription on, one of the CAM modules without the subscriptions sends "Access Denied" info through the OSD. In the meanwhile the other cam module with valid subscription is decrypting the channel and showing the proper content. In the result when I enter such a channel I always have to press OK in OSD CAM "Access Denied" info. Is there a way to disable all OSD CAM infos?
