majstang Posted August 3, 2012 Posted August 3, 2012 (edited) Following place holders do exist (CAPITALS MANDATORY): {FILENAME_EXT} 04-11_20-10-04_RTL 2_Stargate.ts {SOURCE_FILE} c:\capture\4-11_20-10-04_RTL 2_Stargate.ts {PATH_FILENAME} c:\capture\4-11_20-10-04_RTL 2_Stargate {FILENAME} 04-11_20-10-04_RTL 2_Stargate {PATH} c:\capture\ {EXT} .ts {CHANNEL} RTL 2 {TITLE} Stargate {SUBTITLE} Episode 2 Having a possibility to get video/audio format directly as a place holder when recording finishes would be awesome since it is often used/required when invoking command line tools (video editing). For example MPEG2, H.264, AC3, MPEG AUDIO... Any chance? Edited August 3, 2012 by majstang
majstang Posted May 21, 2013 Author Posted May 21, 2013 Having one more go at trying to convince Lars adding some needed place holders for video/audio format. All capturing software should be abled to pass especially video format parameters to scripts IMHO. RS can't do such basic stuff at the moment, which is a pity. I'm forced to retrieve these parameters from the explorer file properties using a timeconsuming function and RegExMatching the results These place holders are the only ones missing, if added the list would be complete. Please, consider it again
