Service crash, when epg search start.
I add new HD channels, and now service start crashing every time when i try to do epg search.
Service just start and stop all time. I have to remove searches.xml and then those HD-channels.
files.zip
could you please provide your channels.dat and config\epg.dat files?
Now i have to go work.
e+c.zip
Edited by janip
This search: "Myytinmurtajat"
^Myytinmurtajat((?!\(R\)).)*$
cases troubles in the perlregex engine (Stackoverflow). This spills over into the RS and everything crashes.
Seems to be a bug in the perlregex engine. Unfortunatly I can't fix this, because this is a third party lib. Please try to change the regular expression.
Edit:
It's seems it's enough, if you disable the "search in Description" field in this search.
