jonyx Posted August 30, 2012 Posted August 30, 2012 Hello, I apologize for my english. I buy DVBViewer and installed without any problems. But I have a problem on some channels. When I try to record or stream a channel, everything is fine except that there not appears subtitle in file recorded or in live stream which is open in VLC. The problem occurs only on some channels, others works fine and show subtitle in VLC (recorded file or live stream ) In DVBViewer, on all channels in live mode the subtitle appear and is ok. I have checked option for format recording option, teletext, DVB Subtitle, All Audiotracks and on NetStream Plugin settings: Teletext, DVBSubtitle, All Audio, EPG. I put on this site two versions of recorded sample, the first that has subtitles can be selected and viewed with VLC, and the second that has show subtitles in DVBViewer, but it not appears in VLC. Where could be the problem? http://www.sendspace.com/file/ock02t http://www.sendspace.com/file/q3lhy3 Please help me, thanks Quote
highyield Posted August 31, 2012 Posted August 31, 2012 This appears to be a bug in VLC: http://trac.videolan.org/vlc/ticket/2939 Quote
