WuxiIxuw Posted September 8, 2012 Posted September 8, 2012 Hello, Please I am using Windows 7 Ultimate 64, and did updated to latest windows updates. Now I am very confused for which Audio/Video decoders and renderers I should choose as they are too many. All channels are SD only as my card tuner does not support HD. Below are the settings I've in my DVBViewer, please advise for which one I should pick for each decoder and each renderer: Quote
tomas.jurksas Posted September 8, 2012 Posted September 8, 2012 LAV for DVB, Arcsoft for HD video - Video, LAV for SD video, Microsoft for DVD if you need DVD menu LAV for audio EVR Custom render Default direct sound And install latest DVBViewer, now I see you are using old version. Quote
WuxiIxuw Posted September 8, 2012 Author Posted September 8, 2012 LAV for DVBPlease what do you mean or refer to by this? is it under audio or under video decoder? Arcsoft for HD video - Video, LAV for SD video, Microsoft for DVD if you need DVD menuLAV for audio EVR Custom render Default direct sound Please I do not follow, please may you be patient with me as I am still new to this and tell what to choose for each one in order as I did in the picture posted above? I do not mean to make snapshot but I mean to refer or pick a choice for the 9 pictures so I can better understanding.Really thanks for your help And install latest DVBViewer, now I see you are using old version. Yes it is 4.5.0.0 but the reason is that I have a lot of crashes with the latest version while this one is not (old is gold), but will it make any differ? to use the latest version or any good old one? Really thankful for your help. Quote
tomas.jurksas Posted September 8, 2012 Posted September 8, 2012 I'll do some screenshort later, but bigest problem is your all codecs, now you must to set prefered merits, because you can select one codec but DVBViewer can use another. Best way is clean install, after that lastest DirectX from Microsoft using dxwebsetup, LAV Filter codec is also enouth, in some cases some video isn't show correctly with LAV, so for H264 videos, not for DVB-S live stream I'm using Arcsoft, plus automatic refresh rate change by video frame rate. 4.9.6.20 with Win7 x64 works perfect, no crashes. Don't forget to turn off UAC in Windows, antivirus I'm don't use at all. Windows defender is turned off, aero is on. Quote
WuxiIxuw Posted September 8, 2012 Author Posted September 8, 2012 I'll do some screenshort later, That would be awesome indeed. but bigest problem is your all codecsYou mean that I've a lot of codecs!? if this is what you mean, then the reason is that I read a lot that the biggest problem for most DVB software is the right codecs so I install all codecs I know and then let the software itself choose the suitable one. , now you must to set prefered meritsPlease I do not follow your point, please may you clear it a little bit more? , because you can select one codec but DVBViewer can use anotherI did not select anything from the 1st place while DVBViewer do choose on its own. . Best way is clean install, For DVBViewer or Windows itself? after that lastest DirectX from Microsoft using dxwebsetupYou mean this one here:http://www.microsoft.com/en-us/download/details.aspx?id=35 LAV Filter codec is also enouth,is enough for which encoder exactly? in some cases some video isn't show correctly with LAV, so for H264 videos, not for DVB-S live stream I'm using Arcsoft, plus automatic refresh rate change by video frame rate.I am really do not understand this part and I am sure it is my fault because I do not know a lot about this DVB world. 4.9.6.20 with Win7 x64 works perfect, no crashes. How long have you been using it ? or in other words how much time does it last before any crashing? Don't forget to turn off UAC in Windows, antivirus I'm don't use at all. Windows defender is turned off, aero is on.same here Thanks a lot for your time reading my post and sorry for my poor information as I am still new and learning Quote
tomas.jurksas Posted September 8, 2012 Posted September 8, 2012 The higher merit set more prefered codec, like an example you choose one codec, but software uses another, so you must to change merit of codec, this you can do with RadLight Filter Manager Yes the DirectX from that site. DVB is your TV channels from SAT or Cable or ... (Digital Video Broadcast) 4.9.6.20 no crashes at all, I can watch 24 hours in a day. HTPC power options sleep/wakeup, no shudown's at all Quote
WuxiIxuw Posted September 8, 2012 Author Posted September 8, 2012 The higher merit set more prefered codec, like an example you choose one codec, but software uses another, so you must to change merit of codec, this you can do with RadLight Filter Manager Yes the DirectX from that site. DVB is your TV channels from SAT or Cable or ... (Digital Video Broadcast) 4.9.6.20 no crashes at all, I can watch 24 hours in a day. HTPC power options sleep/wakeup, no shudown's at all Well. I've reinstalled windows 7 now. Please did you installed any special codecs or just the mentioned DirectX only? Quote
tomas.jurksas Posted September 8, 2012 Posted September 8, 2012 After clean install of Windows I'm installing Directx Latest video driver, not Windows driver, for nvidia I'm using 306.02 LAV Filter http://forum.doom9.org/showthread.php?t=156191 Night builds of LAV http://roy.orz.hm/lavf-w32-nightlies/ And Arcsoft codec for VC-1 and H264 videos Quote
bogdan1980 Posted September 13, 2012 Posted September 13, 2012 arcsoft freeze image on some pc. what arcsoft version do you use? from haupphauge? Quote
