iriskin Posted September 8, 2012 Posted September 8, 2012 (edited) I just installed 1.21.1. Now whenever i try to switch channel in DVBViewer it just hangs.. and DVBVservice.exe shows 25% CPU load in Task Manager(i have 4core CPU so it's 1 core fully loaded). No such problem with previous versions of Recording Service. edit: and memory usage goes insane. DVBVservice.exe uses 1.5GB after couple of minutes edit2: attached support.zip edit3: screenshots: DVBViewer hanging after i tried to switch the channel: http://i.imgur.com/E6UP5.jpg taskmanager after 30seconds: http://i.imgur.com/eerSr.jpg taskmanager 30seconds later: http://i.imgur.com/T3Eqk.jpg (look at the memory usage) 1 minute later: http://i.imgur.com/huRWZ.jpg edit4: i downgraded to 1.21 and everything is fine again support.zip Edited September 8, 2012 by iriskin
GruberMa Posted September 8, 2012 Posted September 8, 2012 Same here, too. Please find support.zip attached. [removed] § 13 Do not ask for or discuss plugins for descrambling/decrypting pay-tv or key-codes. Although the DVBViewer Pro provides full pay-tv functionality it must only be used in combination with a valid subscription of a pay-tv provider, a tv-card/box featuring a "conditional access module" (CAM)and/or the corresponding "common interface" (CI) with a smart-card. This applies regardless whether software-descrambling is allowed in your country or not. http://www.DVBViewer.tv/forum/index.php?app=forums&module=extras§ion=boardrules
factor Posted September 8, 2012 Posted September 8, 2012 (edited) Same thing here too Edited September 8, 2012 by factor
Lars_MQ Posted September 8, 2012 Posted September 8, 2012 I pulled the 1.21.1 and will upload a version with all changes in the hardware/threading are reversed later tonight.
GruberMa Posted September 8, 2012 Posted September 8, 2012 I pulled the 1.21.1 and will upload a version with all changes in the hardware/threading are reversed later tonight. Thank you very much! If you want to re-implement the new hardware/threading code and need a tester, please let me know. Best regards, GruberMa
Bollermann Posted September 8, 2012 Posted September 8, 2012 I pulled the 1.21.1 and will upload a version with all changes in the hardware/threading are reversed later tonight. und warum nur in englisch?
Jay0r Posted September 8, 2012 Posted September 8, 2012 I pulled the 1.21.1 and will upload a version with all changes in the hardware/threading are reversed later tonight. Gosh, i have the same problem with switching chanels... i spend the whole day to solve the isue, i better should have read the forum first -.-" ... anyway i realy would like to watch tv but its impossible at the moment because at the download center isnt even a old version of the RS wich i could use instead... Do you have a estimation time for the release or better an download link where i could download an older version of the recording service? Regards Julian
Derrick Posted September 8, 2012 Posted September 8, 2012 anyway i realy would like to watch tv but its impossible at the moment because at the download center isnt even a old version of the RS wich i could use instead... ..just stop the RS and activate the hardware devices in the DVBViewer
iriskin Posted September 8, 2012 Author Posted September 8, 2012 (edited) 1.21.2 is out. Thank you, devs! It works great now. Edited September 8, 2012 by iriskin
majstang Posted September 8, 2012 Posted September 8, 2012 So if understanding this correct there's no difference between 1.21.0 and 1.21.2, yes?
Lars_MQ Posted September 8, 2012 Posted September 8, 2012 Wrong. The hardware framework has been reset to the "old" handling prior 1.20 due to serious problems with the plugin API.
majstang Posted September 8, 2012 Posted September 8, 2012 Thanks for the information. Was asking cuz the hardware framework changes in RS 1.20.0 (1.21.0) didn't give me any problems until the changes made in 1.21.1. I guess it depends which plug-ins you are using.
