A false positive DVB Viewer Pro v4.9.6.20's Plugins\ImportTSP
Hi!
Overnight, I did a full/complete scan with SUPERAntiSpyware (free edition) v5.5.1016 on my very old, updated Windows XP Pro. SP3 machine. It found my D:\winstuff\DVBViewerPro\Plugins\ImportTSP.dll possibly infected. I checked this file with the online scanners and got a few hits:
http://virusscan.jotti.org/en/scanresult/755c2ce89647f2b723b69668c595e8bb9a518ef2 (ClamAV)
http://r.virscan.org/report/a503683f64380937f5b0fcae027020eb.html (ClamAV and Quick Heal)
http://vscan.novirusthanks.org/analysis/3ebdc7637bccded62ffa4a2748513080/aW1wb3J0dHNwLWRsbA==/ (Comodo and TrendMicro)
https://www.virustotal.com/file/8670f85e989e2bc330e408da6a66cdcf0f24b2345caf9c520f54649ab26f10af/analysis/1347205299/ (TrendMicro and TrendMicro-HouseCall with latest results)
I don't know if this plugin is very old and I don't think I use it? Here is what my directory listing looks like:
dir.exe /o:n /s D:\winstuff\DVBViewerPro\Plugins
Volume in drive D is d
Volume Serial Number is ...
Directory of D:\winstuff\DVBViewerPro\Plugins
06/02/2012 08:01 PM <DIR> .
06/02/2012 08:01 PM <DIR> ..
09/24/2006 12:13 AM 0 DVBSource.ini
03/02/2012 01:49 AM 100,352 ImportCSV.dll
12/08/2002 10:39 AM 185,344 ImportMDB.dll
06/19/2003 01:13 AM 12,288 ImportSDX.dll
09/29/2003 02:35 PM 24,064 ImportTSP.dll
07/24/2009 08:48 AM 215,552 NetStreaming.dll
01/22/2009 02:19 AM 60,928 PostProcessor.dll
03/02/2011 03:15 AM 873 PostProcessor.ini
03/02/2011 03:22 AM 18,533 PostProcessor_ReadMe.rtf
11/05/2010 01:08 AM 556,032 PreviewW.exe
12/11/2010 08:45 PM 800,256 TSPlayer.exe
11/05/2010 01:00 AM 4,794 TSPlayer_ReadMe.rtf
06/25/2008 07:22 AM 89,600 UniStreaming.dll
03/23/2006 10:08 PM 147 unregisterASF.bat
09/24/2006 12:55 AM 283 VRPlugin.ini
15 File(s) 2,069,046 bytes
Total Files Listed:
2 Dir(s) 187,819,069,440 bytes free
Is this a real infection or a false positive? Is mine outdated? If it is, then where can I get updated ones?
Thank you in advance. :)
Edited by antdude
It's a very old and out-dated plugin for importing TechniSat channellists. You won't need it.
Thanks. Do I only delete that file only? All of Import*.dll? It would be nice to clean this old mess up. :)
Only ImportCSV.dll (for importing and exporting channel lists as *.csv [Comma-separated values]) comes with the current DVBViewer Version.
You can delete all Import*.dll
I am confused. You said delete import*.dll, but the latest DVBViewer Pro has ImportCSV.dll file.
You can delete all Import*.dll. They are not mandatory. However, ImportCSV.dll might be useful if you want to rework your channellist with database software.
Ah OK. I will keep ImportCSV.dll file just in case. Thanks! :)
  • 1 month later...
I found another possible false positive, but I don't think this file is part of Pro. Several anti-malware/AV programs say DVBViewer Technisat Edition v4.5.1.28's SkystarIR.exe has an infection:
http://vscan.novirusthanks.org/analysis/1ec64621d6ef0be87fa4dc09a64c9ea3/c2t5c3RhcmlyLWV4ZQ==/
https://www.virustotal.com/file/e33d469de468e2480e2e6a9c1fa415b1818bf2f171eb155824bcf5b8d100438f/analysis/1350663266/
http://r.virscan.org/report/6d9fc1adc42d6ca9c1302c5af2261778.html
http://virusscan.jotti.org/en/scanresult/c3e68629b3849ab4a326ddb89204140cad7c5c34
Malwarebytes Anti-Malware v1.65.1.1000 says it is a Spyware.Zbot.
I e-mailed hackbart DVBViewer.com and support@technisat.de about it. smile.gif
Yes and i already answered you:
this is a classic false alarm, probably caused by thefact that the binary is upx-compressed. You do not the binary in general, sincethe infrared control is handled via the ir dll's inside the DVBViewer-pluginfolders.
Christian
Christian
Thanks. Do I still need this file or is it very old? It is dated 4/17/2008. Edited by antdude
