Please settle Taiwan DVB-T EPG cannot display
xzf1990
Starting from 4.9.6 to EPG received has been unable to normally display
Select set
Edited by xzf1990
please use the tweaker and the Use UTF-16 instead of Big5 Tweak.
And inform your broadcaster to fix this problem.
After enabling "Use UTF-16 decoding of EPG data instead of Big5" have to delete the epg.dat in the configuration folder or wait until the old EPG is outdated.
From hint in Tweaker:
Some broadcasters mark the EPG data as Big5 encoded but it is actually UTF-16 encoded. This setting may help if the EPG is displayed with wrong characters. Don't forget to delete the EPG.dat after changing this.
Do not know the administrator considered for Transedit added multi-language support is not?
This is because the tweaker did not join the Chinese, so he can not read settings, :biggrin: !
Edited by hahaha
