Stream errors only during recording
pataczek
I use Rec. Service with terrestrial TV. As well as a scheduler and a server. Unfortunately it doesn't work flawless. Recording channels from a specific frequency causes stream errors. I tried analyzing it with TransEdit and after 30 minutes there were no missing packets. Streaming a channel to DVBViewer works also correctly. Everything started with version 1.20 or 1.21. Sorry, I can't remember or test it because old versions are not available.
Do you have any advise for me? Maybe some samples will be helpful?
pataczek
  • 1 month later...
