Audio-Filter against loud commercials??
Technofriend
Im searching for a filter or decoder with these features:
"The Yakumo Volume Master will attenuate the sound volume of your TV set when advertising trailers are broadcast. It will always keep to the volume level that you initially adjusted while watching the normal TV programs."
I know Matrix-Mixer doesn't do the job.
VolumeMaster
Help?!
try the normalization of the ac3Filter. Set the master Gain to the highest level an activate "Normalize" and "auto gain control"
It might help a little bit. :(
