Bug - ending recording in wrong time.
jirim100
Please, I have got connect to my computer (Win7 64bits) TWO exact same tuners AVerTV TwinStar (this device is dual tuner). DVBViewer Recording service see these tuners under the same name, in hardware list is difference only with number in parentheses. One device is "AF 9015 BDA Filter 2 (2)" and second is "AF 9015 BDA Filter 2 (4)".
- Now, start recording the program 1 (from mux 1) in 9:40:00 to 11:55:00 with tuner "AF 9015 BDA Filter 2 (2)"
- Then, start recording the program 2 (from mux 2) in 8:45:00 to 10:35:00 with tuner "AF 9015 BDA Filter 2 (4)".
The program 2 was ended successfully in 10:35:00, but the program 1 was ended in wrong time 10:36:22 - not in time 11:55:00 which was in programmed timer but exactly 1:22 after ending program 2. The listed above happens me three times (of course with different times). Wrong ending program 2 stops always 1:22 after first correctly ending program.
Support.zip is attached, but I think the problem is with wrong handling tuners with the same name.
My guess:
22.09.12 11:49:02.553 TBDADevice.CheckAutoRetune Sending retune to AF9015 BDA Filter 2 (4)
22.09.12 11:49:06.384 TRecording.Tick No data within one minute, restarting!
Driver/reception problems. Just take a look at the svcdebug.log and you see the card has some serious problems...
You are right, it's driver problem. It does not correctly handle multiple the same devices.
