RS 1.21.2.0 create very small files when recording
janne67
Hello!
When i send a recording to my RS from EPG an recording start. When i check the webbinterface it´s there but the filesize stops at about 300Kb. Any ideas what can be the problem?
Edited by janne67
Without more informations, I would guess a CAM problem and you are only recording the unencrypted teletext.
I can stream from RS to another computer in the network and that works fine. Can it be the CAM then? My Rs is locatn on a Windows home server 2011.
Edited by janne67
