DVBViewer Crash when first channel is HD
kirschnw
DBV Viewer crashes, when the first channel selected after start of DBVViewer sends in HD (e.g. Das Erste HD or ORF EINS HD ...).
When I select an SD channel first, the problem does not occur. After having displayed an SD channel also HD channels work properly.
Have you tryedto use another video codec for AVC? I recommend you to make a test with LAV filters or Microsoft DTV-DVD video decoder...
