LocalHolgi Posted September 24, 2012 Posted September 24, 2012 I played with XBMC in the past and frankly it is really nice - compared to Mediaportal. Anyway at least on my PC i would never ever change the HTPC solution to something else than DVBViewer. Anyway XBMC runs Bluray disks and i wonder if this would be possible inside the DVBViewer without the usage of third party tools. Since the DVBViewer has a new subtitle engine which also includes BD, i wonder if this will be possible somehow Regards Holgi Quote
hackbart Posted September 25, 2012 Posted September 25, 2012 Well if you mean support for LibAACS you might have luck with the DVBViewer 5.0? Keep in mind that this exclude BD+ discs which are unsupported. Christian Quote
