damianooss Posted September 25, 2012 Posted September 25, 2012 Hi, I have the latest version of DVBViewer, windows 7 x64 and the card Skystar hd2. I have a problem with extended desktop when I move there and act DVBViewer full screen image as if it slows down, you can see it best in the sport with dynamic actions. I have a nvidia graphics card. I might add that it is happening on the full screenshot, if DVBViewer does not act on the full screen image is good. Help I greet all Quote
LocalHolgi Posted September 29, 2012 Posted September 29, 2012 as always: 1. http://www.DVBViewer.tv/forum/topic/2210-how-to-post-bugs-or-problems-correctly/ 2. i suppose you do not use custom renderers. Enable this option under Options->DirectX Quote
damianooss Posted October 6, 2012 Author Posted October 6, 2012 I welcome the break custom renderers have selected. Aero Vsync to be selected? And what should be the refresh rate to hdmi cable? the options have 60hz nvidia cards Quote
Derrick Posted October 10, 2012 Posted October 10, 2012 are you blind? How to post problems/bugs correctly: Always follow these instructions. Otherwise no one can - or wants - to help you!. Please take also a look at the DVBViewer Wiki Quote
damianooss Posted October 10, 2012 Author Posted October 10, 2012 I have a file upload or Supporttool? Quote
damianooss Posted October 22, 2012 Author Posted October 22, 2012 (edited) sorry with before this I did not add. gives a file with my settings, please help support.zip Edited October 22, 2012 by damianooss Quote
damianooss Posted November 5, 2012 Author Posted November 5, 2012 no one has a similar problem with DVBViewer? none of you displays a lcd television on computer is browse the web? Quote
Tjod Posted November 5, 2012 Posted November 5, 2012 I have most of the time (when I use Windows ) DVBViewer open on one screen and Opera on the other screen. But I see no difference if I have DVBViewer open or not in the performance. Quote
