Experiencing a bit of stuttering playing HD channels?
Alaza
Hi there.
I am using a Terratec H7 on a Windows 7 64 bit setup, with a Q6600, 6GB RAM and a nVidia 8800GTX with newest drivers. When playing HD channels on my cable TV I experience a bit of stuttering, which is especially frustrating when watching soccer. Could this be a hardware problem, my gfx card just not being good enough to process the HD channel, or maybe a codec problem? I've tried the DivX and Microsoft I got, and it does seem to a bit worse when using the Microsoft codec.
Hope you can help me out.
Thank you in advance.
try the the cyberlink PowerDVD codec if you have it. LAV codecs are also OK.
I have no problems with HD stuff using Cyberlink.
Frank
Frank
The Cyberlink codec - is it automatically implemented into the codec list in DVB after PowerDVD has been installed?
If you have PowerDVD installed it should be in the drop down list. Otherwise you may have to register the codec again.
Frank
