Lucesat Posted September 29, 2012 Posted September 29, 2012 Hi, I have a problem with jumping Backward/Forward the recorder video. If I press Backward the video starts again, if I press Forward it completely stops and I have to press Play to make it starts again. With music is okay. Why? Version 4.9.9.0. Quote
QBox User Posted September 30, 2012 Posted September 30, 2012 You're using a remote? Sounds like the keys you are using are assigned to "next/previous track". You can change them in Options-Input, using the Learn command if needed. Quote
Lucesat Posted October 6, 2012 Author Posted October 6, 2012 (edited) Does your keys backward/forward work? Anyway, I can't find "input" in the DVBViewer menu Edited October 6, 2012 by Lucesat Quote
