Karolis Posted September 30, 2012 Posted September 30, 2012 Hello, i saw many topics about how to record 2 channels from same transponder, but i would like to ask how to watch 2 channels on same transponder ? i dont want to record, i just want to see 2 channels in different windows. Quote
themaster1 Posted September 30, 2012 Posted September 30, 2012 (edited) Right, use PIP excepted in DVBViewer it's called Preview First go on a channel then activate the preview. You now have 2 windows normal+ small with the same channel .You can change the channel on the large window not the small one butyou can switch windows large <> small which effectively change the channel..so to speak. Same thing for the audio.To do that you have to be in "keys move mode" press on Osd blue to do that. To switch the video windows: press 5 (keys move mode only) To switch audio: press 0 (keys move mode only) Note that it's preferable to use different video/audio codec and renderer for the normal/pip windows Edited October 1, 2012 by themaster1 Quote
