Barleyman Posted October 1, 2012 Posted October 1, 2012 (edited) It seems that keeping "update channellist from recording service" will eventually corrupt the channel list. At least for me. What happens is I get channellist popup with exactly one channel. When I open channel editor, I can see all of the channels. There is no filter as far as I can tell. Wiping everything and reinstalling will fix the problem. Mucking with the channel.dat with channel editor or killing channel list and creating new one from channel scan will not. Also running the setup wizard "from scratch" will fix the problem. DVBViewer 4.9.6.2 Recording service 1.21.2.0 W7 x64 support.zip Edited October 1, 2012 by Barleyman Quote
mixman Posted November 23, 2012 Posted November 23, 2012 I have same problem with last and versions before. Procedure: 1. Clean/delete CH list 2. Import some from ini (Sometimes, not always DVBViewer freezing after importing ch list) 3. Shutdown DVBViewer, start again and in ch list see only one ch 4. Clean again import again and complete list is imported DVBViewer 4.9.6.20 Win7 x64 support.zip Quote
