more2read Posted October 17, 2012 Posted October 17, 2012 Can the Preset Filters be used with Live Satellite Feeds? If so, what would the Conditions be set to? Quote
Tjod Posted October 17, 2012 Posted October 17, 2012 Live TV only works via DVB Source, and there for it only works with formats which are supported by DVB Source. http://www.DVBViewer.com/griga/DVBSource%20E/DVBSource.html And here is the last comment from Griga, the DVB Source developer about Dolby E http://www.DVBViewer.tv/forum/topic/50221-aes-pcm-dolby-e-audio/page__p__371651#entry371651 So without more informations from your side. It is not possible. For people which are interested in the hole discussion, here is the start http://www.DVBViewer.tv/forum/topic/50690-dolby-e/ Quote
more2read Posted October 17, 2012 Author Posted October 17, 2012 Please remove your references to "DolbyE" as it was not part of my question - Thank You. Quote
more2read Posted October 17, 2012 Author Posted October 17, 2012 I mostly use codecs from LAV and FFdshow both using ReClock, but would like to have some Preset Filters for a few special feeds. Quote
