RTSP protocol for IPTV ?
numa
The French Internet Provider "FREE" uses the RTSP protocol to convey the flow of IPTV channels from its TV package.
Do you think it would be possible to integrate this functionality into DVBViewer order to use it with chains "FREE"?
Thank you in advance for your answers and sorry for my poor English.
  • Like 1
In addition: when you enter the address of a string Tv rtsp in DVBViewer, it reads smoothly.
It is therefore sufficient simply to allow the use of a m3u list and translate each line of this list tv channel.
The IPTV device supports only DVB over IP where you have a combination of IP and port for each channel.
http://en.wikipedia.org/wiki/DVB_over_IP
For web-streaming you can use a playlist.
Put all URLs in a play list e.g. .m3u and open it lick a normal file in DVBViewer.
But I can't use it with Recording Service and there is no EPG...
do you think that one day DVBViewer can use this protocol?
  • 2 months later...
Is it possible to use a playlist with RTSP in Recording Service to Stream Channels on the UPNP server?
  • 5 weeks later...
  • 3 weeks later...
