gedav Posted October 20, 2012 Posted October 20, 2012 My Avermedia capture HD 727 card works fine with dvdviewer. It is also a HD capture card with a HDMI input. Can I record an external HD signal in this input using DVBViewer?Is it possible to select this input in DVBViewer? Thanks Quote
PeterDeb Posted November 16, 2012 Posted November 16, 2012 (edited) I have the same card. Have you found any solution? Edited November 16, 2012 by PeterDeb Quote
