Not able to stream all channels
cromag
I'm pretty new to this world, so bare with me :)
I'm having issues streaming some of the channels from the RS.
Some works fine, some don't.
I'm able to see the channels in DVBViewer, so i'm pretty certain that the are not scrambled.
When i try to do a direct stream it gives me a file containing a http://127.0.0.1:7522/upnp/channelstream/14.ts (for the channel not streamable) but http://127.0.0.1:7522/upnp/channelstream/12.ts works fine.
When i click the 14.ts stream wmp or vlc it seems to try to stream, but nothing gets through.
How do i debug this issue ?
If it helps i'm in Copenhagen, Denmark using Yousee Cable TV.
/Cromag
Oh well, i take that back.
I seem to have a different amount of each channel.
The problem was solved as there were more channels, called the same, that i did not see in the first place.
Thanks for watching ;)
Cromag
