Screen saver is not blocked during slide show or radio
dvbrewer
As per title, playing a picture slideshow, even if 'Prevent Screen saver' is selected, the screen saver still comes on, same applies if playing a radio channel.
Edited by dvbrewer
I have the same thing when watching video, even in full screen - Screen saver kicks though 'Prevent Screen Saver' is ticked. Can't put an exact time on when it started to happen. Using all the up-to-date software on a Win7x64 system. Was going to post over the weekend, but didn't get time to check if it was on all video types or just certain ones.
Edited by Cian
That is not the case for me, just on Radio or Pictures, this is on Windows 7 HP 32 bit.
  • 2 months later...
Please fix this issue, it still occurs in 5.0, it makes it impossible to listen to radio or watch slideshows if you have 'on resume, display logon screen' enabled in Windows screen saver options, even if you don't, the screensaver still interrupts slideshows until you press middle mouse button.
Edited by dvbrewer
  • 3 months later...
Thanks for fixing the slideshow issue, unfortunately if you only play music or radio, the screensaver still kicks in, maybe you need to implement automatic visualisation/DVBViewer screensaver in this case?
