ravie Posted November 3, 2012 Posted November 3, 2012 Hello, I have problems with DVBV recording service. I am using a dual tuner DVB stick for recording channels from two multiplexes simmultaneously, which was working well until now. Now, when recording, it works fine, but when I start a scheduled recording from a new channel, the current one stops and only the new one is in progress. I am using two "unicast network device"s. The signal reception is good enough. The only change I have done recently is a new antenna, I installed a new one with much better reception. Help would be appreciated.
Derrick Posted November 3, 2012 Posted November 3, 2012 DVB-T? Maybe you've switched to diversity mode..
ravie Posted November 3, 2012 Author Posted November 3, 2012 DVB-T? Maybe you've switched to diversity mode.. I dont know about it. I did not change any settings. Where can I find this one? Thank you.
ravie Posted November 4, 2012 Author Posted November 4, 2012 It's this one: http://www.terratec.net/en/products/Cinergy_DT_USB_XS_Diversity_1608.html According to the manual, if there are two antennas that are included, it can work in both diversity and dual tuner modes. If there is one antenna (that is what I have now), the manual says it works ONLY in dual tuner mode. However, it seems like it is working ONLY in DIVERSITY mode now...is that possible?
