soldjah00 Posted October 20, 2004 Posted October 20, 2004 hi, i m a new user and i treid to download some plugins..but when i try to enter the members area and enter my name and password the login screen comes again and aigain.... so i´m not able to enter..tell what do i have to do?? Quote
Hartwig Posted October 20, 2004 Posted October 20, 2004 (edited) You must use the login data which you get, when you buy the Pro Version (not the login data of this forum). If you have already buyed it, use this little program to verify your login data. http://www.DVBViewer.com/forum/index.php?a...e=post&id=35101 or set the login data in the URL: for example: http://username:password@www.DVBViewer.com/members/ for "@" in username use %40 for "." in username use %2E Edited October 20, 2004 by Hartwig Quote
Guest Oliver Posted October 20, 2004 Posted October 20, 2004 Did you use the login data you received when purchasing the DVBViewer Pro? You can't log in with your forum account. Bye Quote
soldjah00 Posted October 20, 2004 Author Posted October 20, 2004 i use the TE version of DVBViewer.... of my airstar card...am i not able to dl with this version??? Quote
Hartwig Posted October 20, 2004 Posted October 20, 2004 am i not able to dl with this version??? No, sorry. The DVBViewer Pro is a standalone product. You can purchase it for 15€ http://www.DVBViewer.com/ordering.htm Quote
soldjah00 Posted October 20, 2004 Author Posted October 20, 2004 in the options dialog i m able to search for plugins, but if im not able to dl them what about that function??? Quote
Guest Oliver Posted October 20, 2004 Posted October 20, 2004 in the options dialog i m able to search for plugins, but if im not able to dl them what about that function??? Only the DVBViewer Pro can use plugins, therefore I don't understand your question. Bye Quote
Hartwig Posted October 20, 2004 Posted October 20, 2004 (edited) That's right. But the TE doesn't support any plugins Edit: I think he mean this: Edited October 20, 2004 by Hartwig Quote
Guest Oliver Posted October 20, 2004 Posted October 20, 2004 Maybe, but what is it? Bye, Oliver Quote
Hartwig Posted October 20, 2004 Posted October 20, 2004 Look at the options window of the TE and you'll see it Quote
Griga Posted October 20, 2004 Posted October 20, 2004 The TE only supports plugins for importing different channellist formats, no plugins that extend the functionality. Quote
