Cian Posted November 14, 2012 Posted November 14, 2012 Hi, After many years without a Mac, I have finally taken the plung and built a Mac. It is replacing my old XP "office" computer at home, while still retaining my Win7 PC with DVBViewer/RS on it for Home Theatre. I may occasionally need to get the Mac to show some live DVBViewer channels, so can anyone recommend a viewing client for the Mac. I assume that it would be something such as XBMC, but if there is a nice neat little (free!) program out there that does the job with no fuss, that would be good to know. Thanks, C. Quote
mague Posted November 15, 2012 Posted November 15, 2012 Google for UPnp or DNLA client . Found one free client on the first search http://www.keymolen.com/mediacloudv2.html Quote
Cian Posted November 15, 2012 Author Posted November 15, 2012 I already did the google, but I was hoping to get recommendations from DVBViewer users. Had also tried the software you linked to, but couldn't get it to see live TV, only the recordings. Will keep looking. C. Quote
Goggo16 Posted November 16, 2012 Posted November 16, 2012 Use the VLC-Player. Download the m3u-playlist from your Recording Service and open as playlist in VLC. Works perfect (... on my Macbook Pro via WiFi). OK, EPG and perhaps a couple of other DVBViewer-specific functions do not work as the video is streamed. But the RS-Web gives you all that. Regards Goggo Quote
Cian Posted November 16, 2012 Author Posted November 16, 2012 Use the VLC-Player. Download the m3u-playlist from your Recording Service and open as playlist in VLC. Thanks! That was the issue I was having - how to get the player to see the live streams. Had installed XBMC, but seemed a bit of overkill for a casual monitor of a station. Thanks again. Quote
