Mygica X8558 Pro
Mr. Man-wai Chang
Anyone using this dual-tunner PCIe card? It has two Altobeam 8830 chip, and the latest non-WMC driver is for Vi$ta only.
I am having problem tuning to stations.
Sometimes, green boxes appeared the first time I tuned to a station. Then I needed to jump from station to station to re-tune.
I suspected it's a hardware problem.
Ok, It seemed that I had found the problem. It's Power Saving Plan.
The card was working fine when I set the Power Plan to Maximum Performance.
FYI, I am using an Asrock E350M1 motherboard as HDTV recorder.
If power-saving was the issue, what caused it?
A. the hardware adaptor
B. its driver
C. DVBViewer Recording Service
Edited by Mr. Man-wai Chang
