mcmurdock88 Posted November 19, 2012 Posted November 19, 2012 I have a new installation of Recording service 1.22 + XBMC 12 Frodo. I am trying to start PVR plugin with DVBViewer. But I am a Newbie so I need a little help. So DVBviewr is installed and function, I can see the Live TV. XBMC is runnig good with PVR DVBviwer installed. PVR is Activated. No the server is running locally, or the address is 192.168.1.3 all ports are allowed. But where are ports webserver, streaming port and recording port? I see a lot of ports, but I am nut sure what is what. Could you somebody make a sort manual to set it properly? Or I can arrange some remote desktop to me. Thx very much Ales
Tjod Posted November 19, 2012 Posted November 19, 2012 http://forum.xbmc.org/showthread.php?tid=140645
mcmurdock88 Posted November 19, 2012 Author Posted November 19, 2012 But I thing I have something good set, but...it is not working. And I have icon in the tray and there is Service is no active . I need step by step help, or remote desktop .
A600 Posted November 19, 2012 Posted November 19, 2012 And I have icon in the tray and there is Service is no active . Did you start the service (right mouse button, start recording service)? If the tray icon is grey, the service isn't running so it won't work with XBMC.
Tjod Posted November 19, 2012 Posted November 19, 2012 Dose the Recording Service work with the DVBViewer as client? http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide
mcmurdock88 Posted November 19, 2012 Author Posted November 19, 2012 Did you start the service (right mouse button, start recording service)? If the tray icon is grey, the service isn't running so it won't work with XBMC. yes and no. The icon is orange, but no recording.
mcmurdock88 Posted November 19, 2012 Author Posted November 19, 2012 (edited) Dose the Recording Service work with the DVBViewer as client? http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide DVBViewer is working stand alone (do I have to start here NETstream?). Everything is running on one computer. I have HTPC with tuner and I want to use there XBMC. Thx very much Edited November 19, 2012 by mcmurdock88
Tjod Posted November 19, 2012 Posted November 19, 2012 If you use DVBViewer and Recording Service on one PC you have to configure the DVBViewer as network client. If you use XBMC, it is not relay necessary. But it would be a possibility to the is the Recording Service installation is working correctly.
mcmurdock88 Posted November 19, 2012 Author Posted November 19, 2012 If you use DVBViewer and Recording Service on one PC you have to configure the DVBViewer as network client. If you use XBMC, it is not relay necessary. But it would be a possibility to the is the Recording Service installation is working correctly. If you use DVBViewer and Recording Service on one PC you have to configure the DVBViewer as network client - but how to do it . My steps: 1) install DVBViewer 2) install Recording Service 3) in DVBViewer check for new channels 4) setup Recording Service 5) Try to setup XBMC 6) Try to connect XBMC but PVR is not ready 7) Record service is ready (orange) but not working
Tjod Posted November 19, 2012 Posted November 19, 2012 If you use DVBViewer and Recording Service on one PC you have to configure the DVBViewer as network client - but how to do it .Follow all instructions in this Guidehttp://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide
A600 Posted November 19, 2012 Posted November 19, 2012 Did you configure the XBMC PVR to use the IP of the PC where the RS is installed? If you didn't change any port you shouldn't worry about them because the addon uses the default values.
ASAKURA Posted November 20, 2012 Posted November 20, 2012 (edited) http://htpc.is-great.ru/articles/DVBViewer/xbmc-pvr-DVBViewer-recording-service-pvr.html --- look this!!! and you must use http://mirrors.xbmc....Frodo_beta1.exe and - http://www.dotnetdev...r.DVBViewer.zip Edited January 13, 2013 by Starkun
mcmurdock88 Posted November 22, 2012 Author Posted November 22, 2012 It is working now, thx for help all of you
