DVB viewer error: "Eaccess violation...."
eltio
Here it's what I get on when I open DVBViewer
at first this:
& when I choose ok, this appears:
Can Anyone help? :huh:
Edited by eltio
Hmm,... rename your Setup.ini and try it again. It might help...
OK, go to the options window. There is an option with WinLIRC. You must deactivate it.
I can't desactivate it: I get this message also in this case:
Exactly the same message :huh:
