Technotrend S2-3200 HDTV-S2 and CI module
azimli
hi
I've got Technotrend S2-3200 HDTV-S2 and CI module.
I'm use latest version of DVBViewer.
I've got a problem. I'm bought d-smart nds module and subscription card. This module is working with DVBViewer under Windows Xp Os but not working under Windows 7 Os.
I haven't got any idea for this problem and I need your help.
Best regards,
Emin ...
Edited by azimli
I did what you said thanks but did not work I wonder what else I have to do? :whistle:
  • 1 year later...
Have this same problem, I can't use CI/CAM module with Technotrend S2-3200 HDTV-S2,
Menu View -> Show CAM option also not works.
You need to install the special TechnoTrend support with DVBViewer. There is an according checkbox in the installer.
