Ho to not always search a timer every week ?
skypichat
Hello,
I want to save a timer by the name of a SERIE. I can add one or two Episode by week but I don't want to always do this search every weeks.
In the SearchTimer Webpage I have "SERIE". is it the place to save the name of the TVShows ?
http://en.DVBViewer.tv/wiki/Webinterface_-_Search_EPG#Search_Results
thanks if you can help ;)
Edited by skypichat
Use the search-preset to create the regular search and save it. Running the auto-search task will then execute the saved search.
Create a timer (daily/weekly, depending on how often you want to update your EPG) and include the autosearch task. The timer can just be a "Tune" rather than "Record". I tune mine daily for 1 minute to the station that carries the full EPG details.
perfect, it's exactly what I want
thank you very much
