vladaepro Posted December 4, 2012 Posted December 4, 2012 Hi i'm using DVBViewer for a few years. Was on XP since last month and was using VMR custom renderer. After upgrade to Windows 7, i start using EVR, but i have noticed difference in scaling quality. When i watch same thing on EVR and VMR, EVR looks more pixelated when watching SD channels. Like the filtering is not applied when resizing context to the full TV res (1920x1080). HD channels are 1920x1080 so difference is not noticeable as there's no scaling. I have tried different codecs, but seems not related to them, but only of renderer type selected. Is anyone else experiencing such issue, and is there some solution/tweak i can try to improve the image quality on EVR? If possible I would use VMR instead of EVR (as i was used on XP), but it's not working in d3d exclusive mode since i upgraded to Windows 7 (and on'y with d3d i have stable stutter free image)... I'm using Integrated Intel HD 2500 graphics if that's matter (but it's displaying 1080i channels without a glitch, so power of card is probably not an issue?) Thanx Quote
