"No suitable splitter was found" msg on RadLight while trying
I am using RadLight 4 to play videos as it's my favorite program. From radlight.com
I have installed quicktime, ffdshow and just installed RadLight but I get the msg while opening file on RadLight:
# RLGB error : No suitable splitter was found
The file opens fine on WMP.
Mediainfo gives the following info about the video content in case you need it:
AVC (High@L4.0)(CABAC/5 Ref Frames)
I have tried enabling and disabling codec H.264 on ffdshow but same results, I can even play it on WMP with the codec disabled on ffdshow I believe it's due to having quicktime, there is some graph build needed or some "Source and Splitter filter configuration" to configure here is a screenshot:
play video
Which container format? AVI? MKV? TS? MPG? Or something else? A suitable splitter is required for unpacking video/audio data from the container.
Maybe it will help to install a DirectShow splitter that covers several container formats, like Haali Splitter or LAV Splitter.
Sorry the title is wrong I was going to say while trying to play an mp4 file.
I unistalled ffdshow and installed lav filters 0.54.1 but the same problem persists what am I doing wrong?
Why? ffdshow is no splitter. It is a decoder.
Dunno. May you should ask in the RadLight Forum (if there is any). Here DVBViewer plays MP4 files quite happily with the LAV splitter.
Do I need a DVB card to use the dvbplayer?
Not at all, however is up to you to provide your S.O. with necessary codecs/splitters...
but beware of codec-paks, they can completely and definitively upset you DirectX chain!
:bye:
:bye:
what are the dxchains? like video plays using dx by default?
btw is the dvb cool?
