Nayef Posted December 23, 2012 Posted December 23, 2012 Hi today update RS to 1.23 ... same 1.22 not support multi record in same time ... any help dear staff ?
Tjod Posted December 23, 2012 Posted December 23, 2012 No problem here with RS 1.23 and multiple recordings at the seam time. support.zip ?
Nayef Posted December 24, 2012 Author Posted December 24, 2012 No problem here with RS 1.23 and multiple recordings at the seam time. support.zip ? here my info support.zip
Tjod Posted December 24, 2012 Posted December 24, 2012 You have enabled Debug UPnP which result in a svcdebug.log >> disable "Debug UPnP" And a WMC Service is ruing on your PC. Which blocks the TV card from time to time. MS Media Center Receiver Service: Running
Nayef Posted December 24, 2012 Author Posted December 24, 2012 You have enabled Debug UPnP which result in a svcdebug.log >> disable "Debug UPnP" And a WMC Service is ruing on your PC. Which blocks the TV card from time to time. again i try disable "Debug UPnP" & disable WMC SER ... but not help me ! Still Red recorder time in same time
