Multiple instances of DVB Viewer?
ddichiera
Hi everyone,
I've searched high and low and can't find the answer to my question. Can I run multiple simultaneous instances of DVBV? I seem to remember there was an option to enable or disable this, but I now can't find it or any reference.
In essence, I have a multiscreen display setup and I would like to have multiple instances of DVBV running, one in each display, with different channels. Can it be done?
Or do I need to use VLC, etc?
BTW:I'm streaming from the Rec Service on another PC.
Thanks in advance for any advice.
Dominic
That worked!
(I had looked at that page, but misunderstood the point of it)
Thanks,
Dominic
