Issue playing Blu rays
ramonchin
Hi.
Today I've upgraded to DVBViewer 5, and I've noticed it can't play blu ray folders (screen remains black, no sound) but m2ts files work.
Help please.
Hi.
Help please.
Did the previous DVBViewer version work with this, or previous Betas only?
It had been working since several versions ago
I see the changelog for 5.0says
"Add: Support for LibAACS. You should be able to play Bluray Discs without using third party tools inside the DVBViewer. Attention: You need a working build of LibAACS."
are you using a third party tool tool to decrypt, or are your rips already decrypted?
Did you read the whole sentence?...
Hi Cinch.
Hi I've installed last version of "LAV filters" and Libaacs.
Now I can play both, encrypted and decrypted blurays on VLC 2.0.5, but only decrypted on DVBViewer 5.0.
On the other hand, bluray subtitles aren't showed.
Why..?
Hi Cinch.
Why..?
Blu ray subtitles working here in DVBViewer from disc, though I have AnyDVD HD, not sure if that makes a difference.
Edited by dvbrewer
Do subtitles show on blu ray folders (from hdd)?
Sorry, can't confirm as I haven't ripped any yet.
Did you put the "libaacs.dll" in the direcory "\Program files\DVBViewer" and the key file to "\Program Data\aacs" ?
Solved!
Thanks, I couldn't find that info on any document.
For decrypted blurays too?
Haven't updated to 5.0 yet because of the problems some users reported with bluray playback.
Which is a working version of libaaacs?
Only for encrypted Blu-Rays...
Edited by SnoopyDog
Now I can watch both encrypted and decrypted with subtitles
Enviado desde mi GT-I9100
